XPR 6550 struggle bus
crash2458
Springfield, Ohio
I have several XPR 6550 radios that have been in storage for a long time as we have moved to a 700mhz system. Looking to reallocate these to our road department who still use a VHF repeater system. I have the Mototrbo CPS 2.0 but it will not read due to a n error. 101005 wrong codeplug version is as far as I can get. I have tried reading some other threads but I am having difficulty following them. Any help would be greatly appreciated.
Firebuff880
Boynton Beach, FL
Go to the Utilities section on the radio and see what Firmware is in it -- Latest for 6000 is 1.12.17 and yes you can program with CPS or RM if you have that firmware, but there are many old version that are not compatible and some that are even not compatible with CPS 16.
You have to determine where you are to build a plan forward..
WRYQ397
Thanks to all of the help. I was able to get what I needed taken care of.
Hi Crash,
I think I need more participation in order to PM you, however I was hoping to reach a similar conclusion as you. I've had two radios sitting for 7 years and completely forgot what I set the lock to. I actually don't remember setting a lock at all! Hoping to hear from you. Let me know if I need to post my email address.
crash2458
Springfield, Ohio
I had to find the older CPS version that last programmed the radio to update the firmware. It took some searching but I was able to find it.Screenshot 2023-10-13 123616.jpg
