XPR 6580 CPS Wrong Region
CatLover1234
I picked up a used XPR 6580 and went to program it with CPS but when I tried to read the radio, I get error code #1057 Wrong Region. I've tried numerous versions of CPS and even EMEA editions and nothing will read it.
The model number is AAH55UCH9LB1AN, the firmware version is R01.05.00 and the CP version according to the radio is 02.00.04
Can anyone give some assistance with this?
CatLover1234
I've tried CPS old as 6.5 all the way up to 16 and i still get the error. Tried a few EMEA versions too and nothing worked.
I'd update the firmware but I do not have access to that. Even i did, I couldn't update it due to the CPS not working.
Floridarailfanning
East Tennessee
Something is clearly amiss. The AAH55UCH9LB1AN is indeed a US model radio so you must not have the right region of CPS. Where are you getting your multiple regions of CPS from?
CatLover1234
I was able to get it to read finally, next hurdel is the firmware and then the conversion package from trunking to a conventional radio.
