You have to pre-define messages in a list. For instance message one would be "I am enroute to home" and it would be programmed as such in both radios. Then when you send via MDC, the radio just squawks something to the effect of "STATUS 1" and your radio translates that into the canned message pre-programmed in the radio. That's how analog MDC messaging works. Whether the currect firmware and CPS supports that anymore I can't tell you. Like many others we stopped updating before CPS 2.0 was required.
Hello Shawn,
The steps to sending or receiving messages is about the same as in digital. I also somewhat understand how it works. The problem is, I don't know how to program it in CPS.
For example, where in CPS do I write the predetermined messages that are to be used in analog? For Digital you add them under "Text Messages". But those don't show up when I try to use Quick Text when in analog.
At first, my contact wasn't showing up either (Only on Digital). Turns out I had to select the MDC option under the Contact. After entering the info needed, now the contact is available in analog as well.
There are more steps that still rrequired in CPS. But I dont know what they are.
That's my question to this forum...
How do I program CPS for analog messaging to work? I need the Steps!, or at the very least where to go. I've searched Youtube and found no videos showing the process.
Thank you.
