DiGiTaLD
- Joined
- Aug 10, 2005
- Messages
- 787
- Reaction score
- 106
XPR 7550e UHF
Model H56RDN9RA1AN
Firmware ID 0C78E1B906C54D3A8F264CE5C4F0B9DF
Firmware Version R02.10.05.0002
Codeplug Version 15.05.06
MOTOTRBO CPS 2.0 Version 2.110.120.0 (Legal CPS from MOL)
I have programmed an absolutely identical XPR 7550e (within 2 consecutive serial numbers) with a high/low power button in the past with zero issues. For some reason, despite trying to assign the function to several different buttons (at different times) I cannot get the function to work on this particular radio. I also have it enabled as a menu item in the radio's menu, and I can't see it there either. On channels that are set in the codeplug to high power, I can't select low, and on channels set to low power in the codeplug, I can't set high power. I've gone through this codeplug set by set but don't see anything apparent. Has anyone else had this problem?
All buttons check OK in test mode so I know it is not a dead button.
Model H56RDN9RA1AN
