XPR 8400 repeater on Brandmeister- Continous transmit Problem
KC4YIN
Kinston NC
I have an XPR 8400 repeater on Brandmeister here in eastern N.C. This morning I keyed up the repeater on the Hurricane net -3112 talkgroup and the repeater immediately locked up in transmit mode and displayed my I.D.
I understand that the beacon duration should be set to 4320 milliseconds and the interval set to 60 seconds according to the Brandmeister instructions for Motorola repeaters. My interval was accidentally set to 600 second. As soon as I unplugged the network cable, the repeater unkeyed. Would this incorrect interval setting cause the continuous transmit or are there any other things I should look for? Would like to get this corrected quickly as we are expecting hurricane Dorian in a few days.
Thanks.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Repeater ID, repeater udp port, beacon duration, beacon interval, and IP network info are all critical. TT
TampaTyron
Phoenix, AZ
What does you duplexer and coax and antenna look like (type, length, age, connectors, etc)? TT
