XPR antenna on a XTS2500
BlackSheepDue
Naples, ME
I just picked up a xts2500I vhf and it came with a rather long antenna so I tried throwing on my vhf stubby from a HT1250 but that doesn’t have the right connector so I tried a the vhf stubby off my xpr7550 and that screwed right in so I thought I was set but I came to the realization that I wasn’t receiving anything. I tried transmitting and that worked fine. Any ideas as to why this is?
FYI I also tried the stock xpr7550 vhf antenna.
-Thomas
dgruber
-Thomas
The Xpr 7550 is a different connector then the Xts 2500. The Xts uses a SMA connector.
Sent from my 0PJA2 using Tapatalk
BlackSheepDue
Naples, ME
As far as I can tell one has a pin in the middle and one doesn’t but both antennas have the hole for said pin so I just assumed they would both work. That still doesn’t answer the question of why xts transmits fine with a xpr antenna
crazyboy
NJ
Because it does not transmit “fine.” Just because it transmits does not mean it is doing so effectively and correctly. I would bet you could transmit with no antenna and still receive the signal on what you are using as a receiver to test this if close by.
BlackSheepDue
Naples, ME
Fair point. Most of what I tried was with the receiving radio right next to me but I did try hitting a repeater in town and that worked as well. Guess it was just a happy coincidence. Thanks for your help by the way.
N4KVE
PALM BEACH, FLORIDA
Absolutely do NOT use the XPR7550 antenna on any XTS radio. The 7550 antenna does not have a center pin. However the XPR6550 antenna does have the center pin, & will work fine. Matter of fact, I use the XTS antenna on my XPR6550, & 6350.
IAmSixNine
Dallas, TX
OH man.. We had a sales person years ago who tried to put a HT1250 antenna on a HT1000. Shorted the RF deck in the radio. HT1250 had no center pin and when she put that antenna on the HT1000 it shorted out the radio when she keyed up.
BlackSheepDue
Naples, ME
Duely noted, that’s why I inquired.
BlackSheepDue
Naples, ME
Well I’m sure glad that didn’t happen to me!
Project25_MASTR
TX-COMU
Texas
I do that for my XPR6580’s. Beats the dong of an antenna they come with.
Now, I actually have a VHF XPR6000 stub on my Astro Saber…
