XPR Legacy R02.50.05 Upgrade Path
StephenWyker
Hey All -- New to the threads here. Looking to find the "official" upgrade path to get these radios on R02.09.xx -- I have both MOL and myview access and appropriate CPS enablements, but can not find the correct download location for legacy firmware. My current version of CPS (16) or 2.0 will not allow me to update or recover these radios. It seems I need an older version.
Can someone help me with that location of both legacy CPS and firmware files to help my upgrade? I've called Motorola a bunch and they just send me to transfer hell. Any help would be massively appreciated.
StephenWyker
I know that; but only CPS 16.5 and the newest firmware is located there. I have those. I need the legacy versions so I can update, as there is no direct path from 2.05 to 2.09 without going to 2.06 first, which requires an older version of CPS as well
com501
If you have CPS 16 Build 828 you should be able to read a legacy radio back to about version 13FW.
1.12.17 is newest for legacy, normally. You CAN go to FW 2.09 on certain models. Anything past 2.09 requires CPS2 to read and program.
Keep in find that Motorola changed how they number firmware versions midstream here and it is absolutely confusing.
