XPR series APRS capable
Ops8
Is the XPR5550 or 7550 capable of APRS? I know I need an external hardware or software TNC (direwolf or mobilinkd). But how difficult is it to actually get it working? I've found a few things here and there about wiring it up and getting VOX to work.
I asked elsewhere and was told the XPR series did too much audio processing for this to work? Is that true even on an analog channel?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I don't see any reason why it shouldn't work. Take the appropriate signals off of the rear connector and you should be good.
From the Repeater Builder website: xpr-acc-conn-doc.pdf (repeater-builder.com)
Pin 11 TX Audio
Pin 12 Audio Ground
Pin 14 Receive Live Audio
Pin 16 Ground
Pin 18 Ground
Pin 17 PTT
Pin 12 can be set for flat audio in CPS.
Ops8
Pin 11 TX Audio
Pin 12 Audio Ground
Pin 16 Ground
Pin 18 Ground
Pin 17 PTT
This is awesome info, thanks! I know the XPR isn't known to be used for this but run what you have, right?
