XPR Zone position
Rudy3145
New York
MOTOTRBO software allows you to place your zones in the position you want them. But then when I write the XPR - the zones default alphabetically. Any way to stop this?
otobmark
NC
Not directly. You can put a number plus one space in front of each zone. You might have to start numbering with 11 instead of 1 for it to work correctly (maybe 01, 02 etc) but you can start with 1 and see if it works. Numbers come first in order, then letters so anything not beginning with a number will come after all the numbers and in alphabetical order.
otobmark
NC
To clarify last post, After the number and the space you can then put in alpha zone name ie: 12 HOME ZONE, 13 LOGISTICS etc. and so on.
kg6nlw
Railroad & Ham Radio Extrodinare
Sonoma Co., California
I use 00-21 for my zones, so 00 HOME, 01 BACKUP, 02 COUNTY1, 03 COUNTY2, etc...
Regards,
-Frank C.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Are you changing Zone's through the menu or have you assigned Zone Up/Down buttons and or changed the rotary knob to change zones instead of channels?
