Xpr2500 scan list
LowderK
LEO / Paramedic
Western Oklahoma
Ok i have an xpr2500 that will not let me adjust the scan list.... hit menu and goto scan it will only allow me to turn scan on or off not view edit list... radio has fireware 1.00.00 anyhelp..?
K2NEC
NA
It might not be enabled in the programming. In the software you can select what you do and don't want to show in the menu.
Floridarailfanning
Tennessee
In CPS go to the Menu tab. Then under Scan make sure Scan, Edit List, and Select New List are all selected. This should give you the ability to View/Edit List and Set Active List in the radios scan menu.
LowderK
LEO / Paramedic
Western Oklahoma
ok I did that all three are checked and still the only option it gives me is to turn scan ON or OFF if you use arrows to go left or right it goes to zone
K2NEC
NA
Can you take a video or something? It should be working now
Forts
Ontario, Canada
That's definitely some old firmware... updating it is the best place to start. If you need the FW file let me know and I'll help you out.
Forts
Ontario, Canada
Turns out the issue was Front Programming Password option on the General Settings tab was set to Disabled. Changing it to User fixed things up.
