XPR3500 Flex Rec List Missing Calls
HT600
We recently programmed 4 XPR3500 radios (Firmeware is R02.08.05.0004) with the Flexible Receive List. There are only three channels in the list. We also added Voice Announcement to these three channels and to the Flex Rec On/Off button. The users now complain that they are missing calls when the Flex Rec list is on. I have witnessed the missed calls when my XPR7550 is stationary on one channel and the XPR3500 radios are in Flex Rec On mode.
Is it possible that the Voice Announcements are overloading the memory or processor? The radios have 50 Cap Plus channels and 25 talk-around channels.
N1GTL
CT
The flexible RX list will only work if your radio is on a CP channel (talk group). It has to be listening to the control channel (rest channel) in order to know when a talk group goes active. You cannot be on a "talk around" channel. In addition, you should not be using the same frequencies as T/A as the repeaters output. Not that you are but to me, the term talk around generally means the repeater output as opposed to a simplex channel. How many talk groups are in your list? All 50 ?!?! I do not believe there is a way to set any one talk group as a priority.
HT600
gotta fess up,
I missed checking the Flexible RX List box under the Menu Tab. Checked that, Cloned the radio and it started receiving the calls. The radio was on a C+ talk group but not one in the list (only 4 talk groups in the list for our supervisors to monitor) The List can only contain 16 talk groups.
I mentioned the 50 talk groups to reference how much memory the radio might be using.
The Flexible Receive List feature is to the Capacity Plus trunking talk groups as the Scan Feature is to Conventional channels.
