XPR3500 (non-e) Firmware question
tropiradio
What is the current situation in regards to firmware updates for the XPR3500? I am aware its a discontinued model, but wonder if there might still be any options left. Reason is I have a radio with FW R02.06.11, CP 04.01.06, and using CPSv16. Basically wanted to use this radio as a demo radio among others to show customers how text messages work, but mine does not have in CPS any related section, nor is there a menu item for it. I'm guessing this could possibly be solved by a firmware update, even an older one that is somewhat more recent than the current.
I found here an older forum thread related to XPR3500 firmware updates, but it is understandably no longer open for further replies.
Thanks.
K2NEC
It uses the same firmware as other Gen 2 radios, therefore it is still supported. The 3500 is a bad demo model for text messaging because it doesnt have a keypad. The 7550(e) would be a better choice.
Word of caution, avoid upgrading firmware to anything beyond 2.09.
tropiradio
Thank you for the warning about the FW upgrade max version. I meant to say canned short text messages, which is basically what can be done with a LKP radio. Problem the 7550's are way too expensive, I have my own but they are a hard sell compared to the 3500, and usually canned texts are much more convenient then typing on a full keypad.
Any idea where I could get the correct FW file? Can the upgrade be done with CPS like an entitlement, or is something else needed?
Thanks again.
tropiradio
Just a follow up, I downloaded Mototrbo Portable firmware 02.09 for CPS 16 NA. I assume this should work with my radio with FW R02.06.11, CP 04.01.06? I did leave out the DL link as I am not sure it is allowed to post them here. If indeed allowed, please let me know and I could add it later.
tropiradio
Thanks for the confirmation Any recommendations as to do and do-not's on how to proceed with the FW upgrade?
Or is it a straight forward procedure? Like Device > Update in CPS? I am running now the portable update packages installation of the FW exe file.
What needs to be done after the FW is completed, will the radio need to be tuned? And I assume the codeplug will be lost and would have to be reloaded.
tropiradio
OK I did install the downloaded 2.09 FW package by executing the file, and it reported to be installed correctly.
Since I have never done this before, still not 100% sure I am doing the upgrade process correctly, so just before I push that no way back button, just wanted to confirm one last time that I am doing this right. Please bear with me on this.
I connected the radio, XPR3500 (non-E), current FW R02.06.11, Codeplug version 04.01.06, and Bootloader version R02.06.10.
I made sure to have a fully charged good battery. In CPS 16b823 opened the DEVICE menu, and selected UPGRADE. It took a bit and then I was presented with the first screen (UPG-1.jpg). Initially both fiels where set to NONE, and the only available option of the Firmware Version field was R02.09.00.0001. There where no options available under the Codeplug Version field. Then once I selected the firmware option the codeplug field automatically presented 14.00.13 (as shown on the second image UPG-2.jpg) which is also the only available option. Odd thing is that there seems to be quite a jump between the current CP version in the radio (04.01.06) and the one the upgrade will provide which again is 14.00.13. Is this normal?
OK so just one last time to be absolutely sure I am not missing anything, or doing something wrong before I hit that OK button where I assume the radio will start to be updated and is basically the point of no return:
Does so far everything look OK and good to GO?
Thanks.
Forts
Ontario, Canada
Yep, everything you listed is 100% normal. If you had installed the wrong firmware package then CPS would give you an error saying 'no matching packages found' (or similar). So after you've selected the codeplug version just click on OK and let it do it's thing. Should only take maybe a minute or less to complete the job (you'll see a progress window like you'd see while reading/writing a codeplug).
K2NEC
Just do it already! You almost literally can't go wrong in upgrading the firmware of a radio. The CPS is pretty idiot proof when it comes to upgrading.
tropiradio
Ok its going now. It got stuck for a minute or so at 17% but now its moving again. At 67% the radio did the turn on tones, and now almost completed. Done, Update Device Successful, and radio rebooted normally.
Stories about FW upgrades gone wrong abound, it seems to be idiot proof only to a certain degree. Better double safe than sorry.
