XPR5550/5550e Control Head Speaker
Floridarailfanning
East Tennessee
Does anyone know what the part number is, or if Motorola even sells, the control head speaker for the XPR5550/5550e mobiles? I need to replace one as its making lots of rattling sounds when the volume is turned up on the radio. It's not an electrical issue or distorted audio, it's clearly a physical problem with the speaker itself. I just wondered if anyone knew, that way I don't have to disassemble the head if it's not a part which can be replaced. Thanks in advance!
This was previously a fleet radio which was missing the RX-audio leveling feature before I added it, so the volume knob potentiometer is also completely worn out from constantly getting adjusted.
Tech21
Do you have an external speaker you can plug in to the accessory plug? Only real choice you have is to call Motorola directly or find a local dealer and ask them real quick.
firefive76
Kansas
You can also find new control heads out there for around $50 which would replace your speaker and volume/power switch without all of the trouble.
Floridarailfanning
East Tennessee
Nope. Due to the install constraints that would not really work anyway. . .
Thanks, I hadn't even though to check the service manual. It has a great exploded view of the disassembly. I honestly don't love the idea of buying a random head off eBay if I can avoid it so I guess I'll see about contacting a CP tomorrow.
