XPR5550 Red flashing LED
QRFactual
LEO Member
Massachusetts
Ok, so I have plugged the 5550 into my laptop and deleted all of the previous channels and have programmed my own information in, and the red light is still flashing. Starting to get frustrated. I'm wondering if it isn't passing its self test?
Floridarailfanning
East Tennessee
Do you hear the Self Pass Indication Tone when radio starts?
Do you have ARTS enabled? Even if ARTS is disabled you might try disabling the audio tone and visual indication.
QRFactual
LEO Member
Massachusetts
I disabled ARTS and the visual indicator, and it still is flashing red. I hear a tone as its turning on and the Motorola logo is on the screen, but nothing after that. I'm guessing It's not passing the self test. Any chance you can share the self test tone on here?
Tech21
What's the freq band of the radio and what's the frequency band of your antenna?
Floridarailfanning
East Tennessee
I checked my CPS for this too however my 5550 is on "Once" and it doesn't seem to have a problem.
But I would still try disabled see if it does anything
Not sure how to attach an audio file but every TRBO radio makes the tone on startup by default. Unless you hear a long "Bonk" tone when starting it's probably not a self-test issue.
Tech21
On your computer, go to C:\C:\Program Files (x86)\Motorola\MOTOTRBO CPS 2.0 or 16.0 if that's what you have\samples\
select the default xpr-5550 codeplug and write that to the radio. Start fresh.
QRFactual
LEO Member
Massachusetts
Ok, so I tried that but get a message saying saying "error #1638 Unable to write, serial number in archive and device must be the same try clone device if applicable.
Tech21
Can you PM me a copy of the codeplug that is currently in the radio? Put the codeplug in a zip file PM it to me. I'll take a look and try to help
K2NEC
What's your model number? I might be able to send you my blank.
QRFactual
LEO Member
Massachusetts
Ok, so after powering the radio up, reprogramming it through CPS and attaching a Larsen Tri Band antenna its still flashing red. Would it make a difference if I was to hook up a GPS to it also? could that be the issue?
