XPR5550e PROGRAMMING HELP WITH A SETTING
nokones
Sun City West, AZ
I just acquired a XPR5550e mobile radio, and I am trying to setup a DMR channel. The DMR setting is Color Code 1 and Talkgroup 99. I have the Zone and Channel set and the Color code. What I can't find, is where is the setting for the Talkgroup code. I have looked all over the CPS and unless its called something else, I can't find where you set the Talkgroup setting.
I'm sure I may be no way near doing this right, but I am trying learn the DMR stuff. I'm lucky just to get a couple of channels setup in this radio. So far, I have one analog semi-duplex channel and now I am trying to set up a simplex digital (DMR) channel. The analog channel does transmit and receive, and I am able to program a key for the talk around feature. The radio puts out just a tad shy of 45 watts.
The help file was useless, and I haven't found anything on You Tube so far. Of course, the installation manual only pertains to the installation and the user's manual appears to not have anything related to the Talkgroup settings. If that subject is in the user's manual it hasn't jumped out and bit me in the ass yet.
Any help would be most appreciated.
GTR8000
NY/NJ Database Guy
BEE00
Digital Contacts. Also no reason to shout when typing the thread title.
nokones
Sun City West, AZ
Sorry, I was in my XTL5000 CPS and forgot twice. 1) when I noticed the first time when I saw it all caps and 2) forgot again after I first noticed before I sent it.
Thanks, I'll take a look in "Digital Contacts"
What is the "OVCM" Checkbox for? Do I need to change anything else? And, is there something in the channel assignment that I need to associate/relate this Digital Contact setting with or does it find this setting automatically.
nokones
Sun City West, AZ
I am going to just operate in the simplex mode with DMR. Do I still need to register and get a radio ID number just to use simplex?
K9KLC
Southwest, IL
Nope ID just like you would on analog. DMR has never met the requirements for ID'ing....you still need to ID with or without a DMR number issued by RadioID.net.
nokones
Sun City West, AZ
Just to be clear, I am not talking about a FCC License Callsign. I am referring to a specific System Radio ID number, and not a PT-T ID for the MDC feature, that IDs the radio for the system. This DMR stuff is all new to me and I am trying to figure this out.
My use for the DMR will be on a simplex DMR channel on a Part 90.35 Business Radio Service frequency..
DeoVindice
P25 Underground
Gadsden Purchase
No, a voluntary Part 97 callsign database isn't relevant to Part 90 operation. If it's your own system, devise an ID range that fits your needs. If it's another entity's system, have them select an ID for your equipment that lines up with their subscriber ID layout.
