XPR6500
RICH421
Bay Shore N.Y.
When I key up and the repeater is still up, when I try and transmit it says channel busy.
I want to turn this off...Can anyone help me..
N4GIX
Hot Springs, AR
That is very impolite. Admit Criteria should be left at Color Code Free to prevent keying up on top of an on going QSO.
N4GIX
Hot Springs, AR
What if OP is trying to have the ability to send codes to control his repeater while someone else is actively jamming it?
Well yes, that would be a special case of course if one is the trustee or control operator. But one exception does not a general use case make...
KG4INW
Midlothian, VA
In analog, all XPR radios default to channel free admit criteria which can be infuriating having to wait for a "repeater tail" to cease transmitting. I don't see how that would be an issue.
N4GIX
Hot Springs, AR
In analog mode, XPR7550 allows either "Always." or "Channel Free". I set mine to "Always" so I don't have to wait for the repeater's tail... :wink:
KG4INW
Midlothian, VA
Exactly! OP hasn't said analog or digital yet. If it is digital, I would recommend leaving it at "Channel Free" as the radio is smart enough to know whether it's still hearing a group call hang time transmission (will allow you to keyup) or a repeated signal on the radio that doesn't have a matching group contact/list for that particular channel (won't allow keyup).
