XPR7550 403-512 Power on Issue
#1
Hey RR,
Just purchased an XPR7550 on FleaBay (I know, big mistake) and the radio reads/writes fine. However, upon powering on it will show the test “MotoTrbo” screen, the green light will flash, and then the screen goes black and the top LED indicator flashes red. Is there a chance this unit was inhibited? It does have the connect plus option installed, and the original codeplug was loaded in a CP+ system.
Vero Beach, FL
#2
Have you tried to write a different a code plug into it? The red light flashes when it scans, looking for a site, or trying to lock on to a CAP+ system. Are you sure night mode isn't turned on? and the brightness is all the way up
#3
I don’t have another codeplug I can try writing in. I tried recovery mode but the radio keeps trying to turn on before the screen just goes black again. Seeming more and more like I got shafted and it’s inhibited.
#4
UPDATE: The radio is now stuck on the “MotoTrbo” screen and continues to try powering on. It “powers on” but cannot proceed to the zone/channel screen.
UPDATE: Radio is now stuck on MotoTrbo screen and cannot even be read/write/clone/recovered. Not sure how to proceed here.
redrock2002
#5
If its in a boot loop I think you have to send it in to be recovered by Motorola. We've had our do that brand new after a wifi update sporadically.
