XPR7550 New Housing Issue
VA3ADP
Mississauga, Ontatrio Canada
Hello all,
I just recently purchased a OEM hosing for my XPR7550. Once I finished the re-housing I noticed when I turned on the radio, the MOTOTRBO trademark screen was not displayed. Just a black screen and it went right to the welcome screen. Any thoughts on what would cause this?
Thank you
Michael
Tech21
Does the radio work otherwise? You may just have to upload your own .bmp image for the splash screen.
Ant9270
The Green Weenie
Do you have the splash intro screen enabled or removed under General Settings?
Tech21
In CPS there should be a "Welcome Bitmap" line right above general settings. It may have not been a feature you had before which is probably why it doesn't show or you may just need to rewrite the codeplug.
VA3ADP
Update. Looks like the new housing wont even communicate with the chassis. Tried plugging in a RSM and programming cable with no luck. Ive have contacted the seller to see if he can send me a replacement.
Ant9270
The Green Weenie
Have you checked your flex connections and seated it properly onto the chassis? Even the slightest bend in the flex or misplacement can throw the whole unit off. I would check those first, if you haven't already.
VA3ADP
Ive seem to of solved half the problem. I swapped out the ribbon connectors, now I've also rewritten the original codepluq and the current codeplug and Mototrbo was displayed on the first power cycle. Every power since then it hasn't been displayed
