XPR XPR7550e audio cuts out for half a second
Tank67
New York
When I monitor certain frequencies (might be all of them) my audio will cut out for a half of second or so before returning to normal and I cannot figure out how to fix it. I figured it might have something to do with my bandwidth for the channel, so I played around with it to no avail. I have the bandwidth set to 25 for the channel in question and I compared it to another XPR7550 (not an e) with the same exact channel specifications (bandwidth 25, etc etc.) and that radio does not have any cut off. Any help is appreciated
Ant9270
The Green Weenie
Are you decoding MDC? The DOS system is wonky on the TRBO series. Even if the settings mesh with the system, it’ll still occasionally cut off the first few seconds of voice.
Tank67
New York
Nope, listening to NYPD analog.
KG4INW
Midlothian, VA
It almost sounds like the squelch is tight then. Press the left arrow button three times followed by the right arrow three times (in that exact order) to enter RSSI mode. What signal strength are you seeing?
Tank67
New York
It’s varying from -86 to -122
KG4INW
Midlothian, VA
-86 is a good strong signal but if it drops to -122 while they're talking, then that would explain it (-122 is around the noise floor). Does it still drop out when you enter Monitor mode? Since your standard 7550 is working properly, in I assume, the exact same location, then there could be something wrong with the e model. Does the standard radio show the same signal levels (while side by side)?
Tank67
New York
I can't enter monitor mode seemingly because I am in RX Only for the channel. But in regards to signal levels I am usually getting a bar better on the 7550e than the regular XPR7550
GTR8000
NY/NJ Database Guy
BEE00
If you have the channels PL'd, remove it and try CSQ. There's really no reason to use PL on NYPD channels, as those T-Band frequencies are exclusive to NYC within hundreds of miles.
If the Monitor button isn't functional, you'll need to change a channel parameter. First, temporarily disable RX Only, then scroll down in the TX section and change Admit Criteria to Always. Remember to re-enable RX Only. Now you should be able to use the Monitor button to open squelch, and if you hold it for a few seconds it will latch open. That's a good way to determine if the signal is dropping out completely, or just fading away from time to time.
K2NEC
I just checked with my 5550 and I believe I have the same problem as you. With my CDM, same antenna, same channel, it sounds perfectly fine. Sounds like it's just something with TRBO radios. I think it has something to do with the RSSI, my CDM is receiving the transmissions even with no bars, while the 5550 is cutting in and out very often.
Floridarailfanning
East Tennessee
I've noticed this with CM300d and XPR5550e radios when used for analog simplex operations. It seems to be an issue with the radio misinterpreting the actual RSSI because the RX audio will often cut out even with one or two bars showing. This is very annoying and seems like something Motorola could very easily fix, though they probably never will. Just another selling point for APX I guess.
Tank67
New York
Tried it on CSQ to no avail, might be a MOTOTRBO issue like the two comments above have stated
N1GTL
CT
Might a system on a nearby frequency be polling? TRBO system with a stronger system?
Tank67
New York
Do you have unlink monitor checked under general settings?
Nope, it's unchecked, I did check it off now and monitor now works
It's there. Change the view in CPS from Basic to Expert.
Ahhhh okay I forgot about expert mode, however when I re-enable RX Only it puts it back onto Channel Only.
I got monitor to work utilizing what Ant said, and listening through monitor nothing is being cut off like it usually is, I double checked my squelch and it has been on normal.
