XPR7550e Out Of Range
gmcmorrow
Hello,
I'm new to radio maintenance. I have a Motorola XPR 7550e that when it turns out, it flashes "out of range" and has a none stop steady almost like two radios stepping on each other. I also can't change the channels, zones, etc. I tried swapping out the antennas with no luck. I wanted to see if I could fix this before sending it out to the vendor. Than you!
K2NEC
What's it programmed for? What are you trying to accomplish? Have you tried to write a new codeplug? Have you verified the info in the codeplug is correct?
a417
new to radio maintenance? who programmed it initially?
Tech21
It's simple, you're out of range of the whatever system it's programmed for or somebody screwed up something in the programming.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
It could be that you are running CapPlus or LCP and have a radio ID higher than 65xxx. What is the radio ID, when did symptoms start, etc? TT
