XPR7580e scan help
pdtek
Back again for more XPR7580e help, I am trying to add menu selectable scan lists. I can get the Scan menu item to appear, then options-Turn off, View/Edit List, and Set Active List. I can create a list but I cannot assign priorities to the members. When I select a member I get options-Edit Affiliation and Delete. Edit Affiliation only allows on or off and I don't know what that does. The complicating factor might be that we are using RX Group lists with Digital RX Group lists for handling emergencies in each zone. Firmware is R02.23.01.1002. I have asked Motorola Tech support for the latest user manual for this version but that was just a waste of time. Any input on scan list member priority possibilities would be greatly appreciated.
Firebuff880
Boynton Beach, FL
What MOTOTRBO topology are you on?
I believe Priorities within the Scan lists are a Cap Max feature. But would have to double-check some things to be sure -
pdtek
Thanks Firebuff880. I modified the digital RX group list and set 2 groups as priorities, 1 and 2. Once I did that I tried scanning and the priority 1 or 2 group will not interrupt and non-priority group in scan. Any input on that?
Firebuff880
Boynton Beach, FL
@pdtek
I think there was another part of this, but I just can't recall what it was. Let me look through some old notes and see if I wrote myself a reminder "How To". Also, maybe have your dealer open a case to see if you can get an answer.
pdtek
Thanks again, If I find out anything else I will pass it on.
