XPR8300 failed upgrade
jkpugh1
Hi All. I have an XPR8300 that failed a firmware upgrade and is now just sitting there with the Power LED on and Disabled LED flashing when it's powered up. The Flashzap device is recognized by Windows, but the CPS doesn't see the radio anymore. Does anyone have any advice for where to go from here?
thanks!
jamie
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
There is a process to boot the repeater in "Boostrap" mode with a jumper plugged into the accessory connector. Once in bootstrap mode, then is is possible to SOMETIMES start the "RECOVER" option on the 8300. I say sometimes because I have about a 33% success rate in recovering these. Good Luck! TT
jkpugh1
Thanks, TT! That's exactly what I figured had to exist somewhere, but I think I've read everything on the internet I can find on these things and coming up empty. Any clues where I can find info on the appropriate pins to jump? Moto wants $450 to repair and it seems like this could be an easy fix.
jamie
TampaTyron
Phoenix, AZ
Tying 16, 17 & 23 together on the accessory port will put the radio into FlashZap mode. There is also a couple of good threads that cover this over on another Canadian based radio site. TT
jkpugh1
Thanks for the info. I believe I found all the info you're referring to and still no dice. Looks like it's going back to Moto for repair. Absolutely amazing that their flat fee to fix these things is nearly half of what they're worth at the moment. Appreciate the help!
jamie
TampaTyron
Phoenix, AZ
Did you try to recover each radio separately? Disconnect the TX and RX bricks from the controller/network card and try to recover them individually. TT
jamie
