XPR8400 not readable from CPS, RDAC not working
anthonydpg
Hi, i wasn't sure if there is something that could have disabled the ability to connect via programming cable to an XPR8400. RDAC connection to the repeater is also not working but i do see an ip as pingable when directly connected via lan cat6. Is there any tricks to getting into a repeater for reprograming? Is there a way to reset the repeater to default settings? I'm trying to do this without initiating a reboot.
thanks
TampaTyron
Tampa, FL
Did you get this resolved? It sounds like you may have a network issue:
-what is the network ip address of the programming computer (wifi or ethernet)?
-have you run rdac on this combination of repeater/network/computer before?
-have you programmed the repeater with this combination before?
I would temporarily change your ethernet or wifi ip address to a different subnet and see if you can program the repeater with the cable...... TT
