XTL 2500 Aux Mic and PTT
Gladstone, NJ
Has anyone actually connected a mic and ptt to the Aux Mic and Aux PTT pins in the accessory port of an XTL 2500? Everything says it should be possible but I have not been able to make it work. I have seen a few posts where people talked about it theoretically -- but no actual experience.
If so what mic did you use? Where there any other settings or hardware changes (other than connecting it) required?
WA0CBW
Shawnee Kansas (Kansas City)
The GPIO pins on the auxiliary port need to be programmed accordingly. As well as provide the correct signal levels. The PTT line is pulled to ground to activate the AUX_MIC input. The microphone should provide about 80 mVrms for 60% deviation and has an AC impedance of 560 ohms. It should be connected to TX audio and Audio ground.
BB
Gladstone, NJ
WA0CBW, thank you for the response.
The programming settings I find are related to mic voltage and gain (auto or a value). Are there others that I need to attend to?
Do you know of a specific handheld (potato-style) mic that has those characteristics? All the mics I tried gave me no modulation at all.
You mention "Audio Ground." All three grounds of the radio: digital, audio (aux jack pins 1 and 14), and chassis seem (to a meter) to be exactly the same. Is there some difference? Which one is "Audio Ground?"
I am beginning to believe I am missing something obvious.
WA0CBW
The pins have a function as described but you have to program the pins for that function. I would guess you got no audio because you didn't program the pins for the function you want. The programming software has a pretty good help screen for each pin.
BB
Gladstone, NJ
Again, thanks for the response. Is that pin programming available in CPS? What tab? Is there any chance you can send me a screen shot of that page/tab? I do not recall any place where I can change the function of the aux connector pins.
