hitechRadio
- Joined
- Dec 23, 2010
- Messages
- 538
When you say scan "All Stations" Channel. Did they program the ALL Stations as the ATG???
Additionally, there were issues with certain FW revisions back then that had issues, Compare the firmware between working and non-working XTL's.
You can check without a computer. Power off radio, then power up, and tap the home button 5times right after it boots and you see your channel name. You will here a strange tone. Take note of the display and it will scroll thru the features, FC, Model, Serial and Firmware,,etc.... Power down and back up to go to normal mode.
Also make sure HUB is set the way you want in CPS, Make sure Mic is grounded if using HUB defeats scan.
