XTL 2500 programing
Shinnysides
I need to lock onto the repeater that stops the scan when I come off hook. Any ideas on how to program this into the code plug?
AlexC
In your scan settings - there's a hook defeats scan options - I think it's in the Scan Configuration box.
Taking your mic off hook will then suspend scan.
-Alex
Shinnysides
In the Scan Config pannel I have HUB Suspends Scan and Suspend all Scan but when I come off hook the controlhead goes to home and does not lock onto the repeater that stopped the scan. Am I missing somethingin the code plug?
Roy
AlexC
I'd highly suggest reading the help file for those features and ensuring you clearly understand how that works. You may also want to adjust the timing that the radio sits on a channel it landed on it give you adequate time to ensure you can pick up the mic in the right amount of time.
Personally, I do not like talk back scan because I've found on more than one occasion that I inadvertently end up landing on a channel I didn't want to talk on.
-Alex
