XTL 2500 softkey problems
dap987
Hello,
Upgraded some XTL 2500's in fleet. When setting the menu items for the 5 soft keys experiencing problems. Menu items are scrambling around on their own after codeplug install or not showing up at all. Programmed the same as the other ones in use, not sure what is happening.
Any Thoughts?
Thank you........
David
RKG
Boston, MA
Hello,
Any Thoughts?
Thank you........
David
Only those menu items that are applicable to the selected channel appear, and different menu arrays will alter the arrangement of the items. (For instance, if you have a menu item for "Phone," it will appear only if the selected channel is phone enabled and disappear if the selected channel is not phone enabled.)
dap987
XTL programming
Thank you that makes sense. With some minor adjustments I have gotten the menus I wanted to work.
