XTL 5000 dual band setup
LowderK
LEO / Paramedic
Western Oklahoma
Ok here is another questions for all the people in the know...... I have a XTL5000 VHF with W series TIB and a 7/800 with W series TIB what is needed to make this into a dual band setup..? can I build my own cables..? does anyone have the part numbers needed..? and also does this require a special flashcode..? thanks
LowderK
LEO / Paramedic
Western Oklahoma
OK to add to this I heard there was setup for the 05 head also but maybe its a government only setup..?
APX7500X2
NY/CT
I had one a while ago, it was into a W3 head but had a separate box that the cables went to then came out of that box with the W3 head
I did see a setup on E-Bay a while back for dual XTL mobiles, I think it went for $1900 with the radios. might see if that guy is still around
marcotor
I ♥ÆS Ø
Sunny SoCal
That eBay guy is an idiot, he took some information that was floating around, and is ripping people off.
Both decks need to be flashed for Dual setup, with the old style dual serial port TIB.
This works with the W3 head only.
W3 plugs into main deck. A regular, plain-Jane serial cable (not a null modem) connects the decks together
via the 2nd port on the TIB's.
No voodoo, magic boxes, Y-Cables, or other wizardry needed.
marcotor
I ♥ÆS Ø
Sunny SoCal
It does? I've never needed any special software or firmware for dual deck installations. Guess I am doing it wrong.
kayn1n32008
ØÆSØ
Sector 001
Both radios need the same firmware, and both need G474 Multi Radio Software. There are schematics on CommSupport for the dual brick cable, and you need a W3 HHCH
kayn1n32008
ØÆSØ
Sector 001
Probably Command Communications. He took the guide from CommSupport, makes his own cables, and sell everything for far more than it's worth.
LowderK
LEO / Paramedic
Western Oklahoma
Ok here is another question when in dual mode I understand main and 2nd radios when main radio is selected can you still scan the aux radio and hear the traffic? I know on the astro spectra and spectra you could it just didn't display the channel on the screen when talking
LowderK
LEO / Paramedic
Western Oklahoma
It’s not like an kenwood or APX dual band tho right as in channel 1 vhf channel 2 uhf etc It’s just two radios into one head
pcorrin
riverside ca
i have the parts you need, its about a 75 dollar investment you just need to add the proper flashcode option to the radios your using, its not as simple as a db25 to db25 jumper, you will end up damaging audio pa
