XTL CPS - Moving Zones
KG5HHS
D/FW
Hello all,
I am using Astro 25 Mobile CPS R20.01.00, I have 14 zones in my XTL5000, and I'm wanting to add a zone in between the current zones 1 and 2. Is there a way to move zones around (like you can move channels to a certain number)?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Expand Zone Channel Assignment, double click on a Zone to open it, click on the table icon in the bottom right, click on Zone 2 and select Insert.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Hello all,
Use the Insert command. Open the zone below where you want the new one to be, and click the yellow "I" in the icon bar at the bottom of the Zone window.
You can also move zones; click and hold the zone you want to move, drag it to where you want it to be and hover over top of a zone above or below there, and let go of the button; a context menu will pop up saying "Overwrite / Move Before / Move After". Just select what you want to do.
Finally, with a zone open, at the right side of the icon bar is an icon that appears as a spreadsheet grid; click that and it will take you to a grid display of the zones. You can right click on a zone and select "Move" when the window pops up. You can also rename the zones there.
KG5HHS
D/FW
Thank you for the info guys! I've been using Astro 25 CPS for several years and had no idea! Thanks again.
