XTL Repeater
nikronzo
A new project I am working is building a small P25 repeater out of 2 UHF XTL's; my goal is to have a low power, low duty cycle P25 machine built out of two XTL2500's. I've done my research and have not seen a lot of info regarding building something like this outside of using XTL's for DVRS'. I know there are a few limitations such as lack of passing on RIDs and duty cycle problems but this is experimental at this stage.
Does anybody have any experience building something like this and if so, what sort of pinouts would I need out of J2 ports in the back. I am looking to build a custom cable for this as well. Also what CPS settings would I be looking at for the Rx and Tx side of things.
Closest helpful info I could find was the PDF of the Astro Spectra Consolette manual appendix A on page 107
Moreover, does everyone think this project is feasible?
jeepsandradios
East of the Mississippi
I built one. Used it once. Swapped in a Quantar.
1 - No it will not pass ID of the radio talking. You will only see the ID of the transmitting radio.
2 - Encryption will not pass thru the repeater. You would need both radios setup for encryption, one to decode and one to encode.
3 - All signals are on J2 however there was a version where the detect circuit changed. Early went high on RX and later went low. (Pin 13 - Channel Activity)
To be honest unless its a one time use thing spend a few $$ and grab a quantar.
prcguy
Yes yes yes on this! A used Quantar will usually cost less than two XTL2500 mobiles.
nikronzo
While this can be true, I already have the XTL's and they arent doing anything as of right now so I wanted to experiment a bit. For the sake of argument, what if I just wanted to do FM with the two mobiles.
I'm waiting for someone to say sell the mobiles and use the cash to buy the quantar, which isn't the worst idea lol
nikronzo
Do you still happen to have the pinouts for the crosspatch cable on the J2 ports?
MTS2000des
5B2_BEE00 Czar
Hams and their fetishes for building repeaters out of mobile radios.
Aside from the obvious as mentioned, XTLs aren't rated for even 50 percent duty cycle. Gas bagging hams with 3 minute keydowns won't lead to much service life.
A Quantar, OTOH, can be keyed up 24/7/365 (as many were used in trunking environments where active CC stayed up continuously) and will never skip a beat.
They are also miles above some uniboard disposable mobile radio in performance in all respects if aligned properly.
nikronzo
Fetish is such a strong word. I prefer mild preoccupation. I have an MTR2k set up as a repeater and love it to death, its duty cycle is unparalleled as I'm sure the quantar is even better.
I just wanted to mess around with the XTL's as a mini repeater as I have never done that before, only with CDM's.
Moto_Dan
I built one just to try it out. The digital audio quality was not horrible, but was not perfect. The radio did heat up rather quickly so if you are dead set on it add a few fans to the TX radio. I have attached below a cable diagram.
jeepsandradios
They work but as said not ideal. Ours was a for a SAR interop unit. Simple and effective but other than voice you loose all the P25 features that benefit from P25 (ID mostly). Still it filled the void for the incident. If it was long term the quantar is the go to for me.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Simoco has a (licensed) function which allows two SRM9000 bricks to become a P25 repeater by simply crossing the RX Data line on one's control head to the TX data line of the other's. They call it Simple P25 Repeater. There are some limitations but for just repeating P25 it works (there's some issue when you try and get it to repeat analog and digital or analog but I can't remember what it is).
Theroretically, that's the 10,000 ft overview of how any P25 repeater works...receiver demodulates datastream and sends it over to the transmitter via serial bus. This is why Quantars don't even have IMBE vocoders in them....all of the vocoding is done by either the SU's, the system or the console. I'm not sure if anyone has ever really figured out a way to pull the SB9600 data off a RX radio and send it back out a TX radio's SB9600 bus (which would eliminate the double vocode issue) though.
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
@nikronzo You should ask our Vodka-named friend about his project.
It seems that when an XTL is tricked into thinking it's connected to a DVRS unit, it passes quite a bit of info out of it including raw IMBE. The right piece of software could connect two XTLs together and not only not double-vocode but also pass all the required data like RIDs. This is all functionality that is standard when an XTL is paired with a DVRS (Digital Vehicular Repeater System).
