XTL Series radio
toolman60
Hello,
Are all the XTL mobile radios wide/narrow band capable.
I have a ID number I cant decipher for an XTL 2500 M21KSM9PW1AN.
flash code :5002A8-801684-1
Can someone tell me if this radio can do conventional narrow/wideband and how it will perform on ham bands.
Also have this one in question: M21URM9PW1AN, M21SSM9PW1AN XTL 2500 uhf unknown flash code
I can not locate any info on M21 XTL radios.
Thank You
Tim
FFPM571
Nashvillle
A simple google search would tell you that all XTL's are narrowband.. and what the frequency range is and since it will cover that range it will perform fine over the specified range. All 3 radios model numbers are found all over the internet with plenty of information
toolman60
Thanks for your help. Yes there is ton's of information on the XTL out there. I was in question of the M21 as in all my paper work on the XTL I can not find any model starting with M21 so just wanted to be sure.
Tim
MSS-Dave
Generally Central Florida
Hello,
Thank You
Tim
1st radio is 50 watt VHF 136-174. Ham band fine. Wide narrow fine.
M21URM is a 700/800 radio. No ham
M21SSM is a 470-520 radio. Not good for ham unless it's hackable in circuit mods to move the range 30 Mhz or more.
The VHF radio is flashed for P25 Trunking as well as other things.
As these radios have been out for eons, there is a metric crapton of posts on RR Batlabs and various blogs with everything you need about this platform.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
N4KVE
PALM BEACH, FLORIDA
M21 is XTL2500. M21SSM is rated 450-520. Not 470-520. Should work at 440 with a hex edit. My friend has one, & it's in spec down to 420 MHz.
