XTL2500 NAS om P25
speaker-mic
The perils of affiliating are well known, as are the mass of problems that come with it. The xtl5000 does the type 2 and astro trunk NAS with no issue. The problem is the xtl2500, which has the proper flash-code, does work with type2 NAS, and p25 conventional, will not hear the system.
It was brought to a local that does the admin of a private system. Looked it over and bench tested it to no avail. It is an older model that was re banded. Said is could not talk or hear their system. Again, let me stress this, it was brought to the appropriate staff member. To the extent that when asked if they could swap it with a unit that was being dumped, they declined [didn't know that trashed stuff was destroyed, thought it was auctioned or recycled].
I hear it may be that the processor is not enough. Was told its too far down a rabbit hole on the tech end for the shop to look at. On a side note, it will scan the system in conventional.
Any ideas?
These units are used with properly licensed conventional frequencies in areas near highways and its less cumbersome to have a single unit in the trucks that's durable because they take a regular beating. They have wiped out some scanners but have yet to take out a W3 xtl5000, just a mic or 2. The xtl2500 is a better option for the supervisor trucks. Since there's not much to be done, the expense for an o5 xtl5000 is out, they don't need all the "bells and whistles", just a front display.
I do the installs and removals. And am somewhat knowledgeable in the mechanics of these so I'm the one doing the leg work.
speaker-mic
From what I have come understand since my post, it is an ancient RB one and the existing codeplug was used. It was not re-flashed or anything for the bench test. They ordered another one, this one will go into the parts bin.
Too bad there isn't a separate transmit and control board like the old Jedi series of xts lines of portables. Once its boned, you toss it, what a waste!!
Thanks anyway.
n3obl
Ø
PA
Honestly you can grab 800 decks on ebay for next to nothing.. usually less than 50 dollars.
speaker-mic
Reband radios aren't different internally from non-rebanded models. Just a flash code/model number difference. These radios are all ancient, the XTL2500s went off support 10 years ago (2015) and haven't been in production since 2010.
I figured that. Whats odd is the flash code is: 5000A8-001480-6
again, its fine on type 2 and analog/digital conventional but not p25 trunk. It was removed from the type 2 use and re-purposed. I know it sat for some time at the shop though.
Again, it will become parts. I give the guys 4 months before they spill or toss something at the one in the truck and destroy some part of it..
