Xtl2500 Speaker
Chesky
Is there any way to hook up the speaker connected as shown in the picture to my car’s audio/ aux without going to crazy on wiring? And adapters?
AK4PY
I would suggest you do not go there. The audio amplifier in the XTL radios (and most Motorola radios) is very sensitive to what speaker you connect it to. It will burn out fast if you don't know what you are doing.
nokones
Sun City West, AZ
The mobile radio audio in my old company car was wired to the vehicle onboard audio speaker system. The answer is yes but it has to be properly engineered. It's just speaker audio levels that need to be matched and/or properly amplified accordingly.
Project25_MASTR
Millennial Graying OBT Guy
Texas
No. That's amplified audio...and it's a push pull PA so when you connect it to your AM/FM either one of two things will happen...you'll blow the input out if sleeve is isolated from DC ground or you'll short the PA on the radio out and not have any audio anymore.
Use the accessory connector and pull RX_Audio if you really want to hook it up to your car's AM/FM.
n3obl
Ø
PA
Some police vehicles do have the passenger door speaker disconnected from the audio and has leads in center console area to hook up to two way radio.
Project25_MASTR
Texas
That's a factory option from the manufacturer actually. Ford CVPI's and PI Utilities had info for where in the harness you could cut and wire into either the front left or front right door speaker. GM might have had the option in the PPV as well. Someone I seem to remember using a plug jumper that you could unplug and then plug in a replacement with splice leads to the radio output (maybe that's a current GM PPV option as it sounds similar to the BCM flasher option for external switches once the BCM is flashed for the option). Horrible use of the OE speakers though...put the speaker up on the partition by the operators head. Easier to hear in noisy environments without the distortion some speakers (cough...Motorola...cough) have issues with at higher volume levels (there is a reason my POV and county truck both have KES-5's for all of the speakers regardless of radio manufacturer as I have a mix of Motorola and Johnson in my trucks).
