XTL2500----->XTL5000
wyomingmedic
Hello all,
Have an XTL2500 for 900mhz. Works fine but I want to use a W3 head, which is supported by the 5k and NOT 2500.
I have all of the 'appropriate' software to force-feed a 5K codeplug into the 2500. I've forced a 5K back to a 2500 in a past endeavor.
My question is: if the 2500 is aligned, will forcing it to be a 5000 mean that I need to realign it? I worry that forcing a whole new tuning partition into the radio will throw it all out of whack. If I save the 2500 tuning values, could I simply replicate them after it is a 5000?
Am I missing anything here?
clbsquared
Isle of Wight County
You should always save the tuning file before you re-flash the radio. With that being said. I've never had an issue losing the tuning values after upgrading a 2500 to a 5000. Just make sure you use the proper TIB and flex for the W3 head.
wyomingmedic
Excellent, thank you. That should make it easier to get this thing installed and functioning.
Ya, I need to keep my eyes open for a W3 TIB. I currently have a W3 setup on a 5k that doesn't have a compliant TIB, but I use the second DB25 position to make it switchable. Not as convenient as the actual TIB but it works for now. And since it isn't affiliating to any trunked system, I don't feel too bad just killing it with that LOL.
Thanks!
