XTL5000 05 head ignition sense question.
W4hlk
Hey, got a 5000 with the 05 head and want to power it on just to be sure it works. Also to disable the ignition senses which I think can be done in the cp. Alas, I've dug around and I don't have a cable. So one is ordered, but this time of year who knows.
Is it just a matter of applying 13.8 to one of the 25 pins? If so, what pin?
K2NEC
5F6
Pin 25
XTL Radio - W9CR
You might also have to put a jumper between pins 14 & 15
W4hlk
Ok, no joy. Hum. Well I don't want to fool around too much. Guess I'll need to wait for the sense cable to see if it works. The guy posted pictures of it powered on. Hope USPS didn't play soccer with it.
K2NEC
5F6
Try to jumper 14 and 15 first and then power up. If that doesn't work then put 12v to pin 25.
EDIT: Also make sure you are putting power to the right pins, the numbering can get a little confusing.
W4hlk
I tried it in the sequence you stated and nothing. As for the pins, they are pretty clearly marked with pin ref numbers at the top and bottoms of each row.
K2NEC
5F6
That should have worked then. Is your power supply supplying enough power to the radio and ignition sense?
W4hlk
Yes. It's a Dimond GZV4000 more than adequate.
K2NEC
5F6
Hmm ok. Update us when you get the harness
W4hlk
Will do. But I have a feeling something happened to it in shipping.
K2NEC
5F6
Is there any visible damage to the radio or any distressed packaging that would suggest that?
W4hlk
No the radio is super clean. Hardly a scuff on it. The box however looked as if it were at the bottom of a palate. Not crushed but looked worn and not firm at all. He wrapped it well in many layers of bubble wrap and peanuts. I do believe him that it was working when he sent it. I think once again the Christmas crew the usps adds on this time of year got to it. I'll just eat it and try again later. I was so hopefull to add this in my console. Oh well, what are you going to do.
K2NEC
5F6
I'd wait for the cable before jumping to any conclusions. Just to be entirely sure.
W4hlk
It didn't take much research on what you gave me to realize, that should have done it. It's a brick. I'll order another.
APX7500X2
NY/CT
Inhibited is an easy fix on an XTL...But if your going to throw the radio away maybe someone would want it for free
W4hlk
It's not inhibited. No power-up. We are working on it.
W4hlk
Also looking around I found this to confirm the pinout and it's right on. In this, they were explaining how to make a programming cable from a stock moto HLN6863. So it all looks right on the pinout
nhfdcadet
CETsr
New Hartford, Ct
do you have the pinout for the db9 connector as well?
