Xtl5000 audio adapter
dustinw251
Franklinton, LA
Im looking for some form of adapter or wiring diagram for hooking up the audio from my xtl5000 to our computer ecording system to record all radio traffic. The kenwood on out vhf works perfect cause it has an audio out. The xtl has a specific plug that goes to the base speaker tray!!! Is there anything available for that function?
cmdrwill
So Cali
Correct Pin 21 which IS line level and is NOT affected by the volume control. AKA Record out.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Note, it will only record audio it hears. Not audio transmitted through it.
But you'll also need pin 1 or 14(ground).
jim202
New Orleans region
Thats what i need just constant audio for on scene traffic and dispatch records.
Be a little careful here as the fixed RX audio does have a DC bias voltage on it. I would suggest using a series capacitor of around 1.0 uf to block the DC voltage.
As far as the speaker wires go, this audio level will be controlled by the radio volume control. Plus you don't want to ground either side of the speaker wires. Doing so will blow the audio output circuit.
