XTL5000 audio issues
elentz91
Murrieta, CA
I have a XTL5000 that suddenly i no longer can hear the radio traffic but the busy light illuminates when there is traffic but no audio still The speaker makes noise for every other reason. I have switched out the antenna, coax, speaker, connected the speaker to the head and the radio it's self with no luck. I was messing with the programming at some point and i don't know if that may be a issue or there is a specific part can go bad that you would receive radio traffic but can't hear it but the radio can make sounds for other functions.
KJ4DHF
Load your backup codeplug back into the radio. See if the audio from speaker is restored.
nokones
Sun City West, AZ
Either add the "PL Defeat" feature in your menu and program the feature to one of your soft programmable buttons or switches and enable the feature, or in the Zone/Channel Assignment set the receiver decoder to "CSQ" to see if that channel is transmitting with a "PL" tone or "DPL" code. If you are able to receive/hear the traffic with the PL Defeat feature enabled or with the receive set for CSQ, than the channel must not have any tone or code, or you have the wrong tone or code programmed for that channel.
Also, to be on the safe side just in case your Scan settings is not set correctly, turn off the scan feature.
