kyle40367
Hello, I have some questions hopefully I can get answered here.
Bought a New truck and I am converting my radios to an all HHCH setup with the factory console.
I have an XTL5000 VHF 110 that used to have a standard XTL5000 remote head. I bought a W3 HHCH HMN4044E. Plugged the radio in, got a 01/90 Fail, saw my home channel then the radio resets. and the display sequence repeats itself. I am waiting for the programming cable (HKN6172B) and the accessory cable (PMLN4959A) to arrive. Is the fail code something simple to be fixed in the CPS since changing the control head but not changing in the CPS?
As well, I bought an 800mhz XTL5000 with the astro remote TIB on it. Plugged the HMN 4044E HHCH into it with the rear plug and ignition sense cable powered but I get nothing on the HHCH. Is that a programming issue as well or is it likely the radio is DOA?
I am going to be converting my XTL5000 UHF R2 Dash Mount to a remote setup too. I want to run the HHCH HMN4044E on that radio. Do I just need the accessory cable PMLN4959A to get that to work as well? or do I need other things as well.
Trying to avoid buying an 03 head for the VHF due to cost.
Thank You in advance.
