Hello all,
I am having an issue where my O3 head will not power up the display when I press the power button. The power button as well as the transmit button will power up a green light for a short time and then the green light goes away. The ignition sense wire is hooked up correctly as I can get another radio to power up with the same wiring job. I also can't get the radio to program right now with either a USB cable or serial cable connected to the GCAI connector. The radio is a 110 watt. Both programming cables are OEM.
Thanks guys,
Dan
Thanks guys,
Dan
