Xtl5000 ignition
Matt9638
So if I leave the radio on. Turn off the car radio stays on. Then start the car the radio turns off. Sometimes. Prior radio was installed in another vehicle using a relay to ignition which imo is no good.
Advice or ideas???
johnoconnor98
Memphis
Need more info.
Dash or remote mount?
Which control head? w4, w7, 05, etc.
It's probably a programming issue, do you have access to modify the program?
Matt9638
Remote mount, O3 HHCH. Like said never had an issue in previous vehicle. Just moved it over to new vehicle.
Yes have programming software.
IMPRES2
Check your ignition settings; if you want to know what the different options mean then simply right click on the drop down menu box and click on "What's this?" And it will bring up the help topic page.
You might also care to check the ignition sense wire coming off the accessory connector on the brick. Ensure it is terminated to an ignition switch circuit from the vehicle (most vehicles have the fuse box located near the battery, I tap from the ignition switched 12V socket and then run fused mains from the battery).
RKG
Boston, MA
I have found some O3s that were flukey re: ignition sense. Check you deck firmware version.
Matt9638
Fixed it. The ignition on Under radio wide~advance was left blank.
