XTL5000 Power Question
LCT123
I have a XTL 5000 in my truck and when I had to put the truck in the shop for some repairs, I took the radio out. I have it wired up so you can RX/TX with the ignition switch off. When you take the radio out, the control will automatically come on in the maintenance mode and display Remote. I am aware that's to let you know there is a problem between the control head and radio. To make a long story short, the repair shop never turned the control head off and they kept having to jump the truck off. Is there anyway to defeat this so it will stay off?
clbsquared
Isle of Wight County
If you want to be able to turn the head on or off, you can run the power and ignition wire through a relay and use a toggle / rocker switch to turn it on or off regardless of the ignition.
