XTL5000 Programming Problems
K9ROD
Boerne, Texas
I am programming a XTL5000 for a trunking system. On a code plug I have for a XTS2500, there is the ability to select the type of personality. ie: Conv or Tk I am basically cloning the two. Everything else is in place and looks good. Am I missing a particular check box, or what? I have a trunking system, but when I open the "Zone Channel Assignment" the box "Personality Type" is missing. I get one is portable and the other is mobile, but the option to select this should be there. Thanks, Rod
clbsquared
Isle of Wight County
If you’re cloning the codeplug from one Astro 25 series radio to another, open both codeplugs and have them side by side on your screen. Load the system keys into both codeplugs. Then you can do a top node drag and drop. Left click/hold on the top of the tree and drag from the cloner, to the clonee . Release the button and wait for the update to finish and then fix your errors, if any. This should carry over any and all pertinent information for your zone channel assignments.
I’ve also seen where some columns are hidden and just need to be expanded under the view selection in the top tool bar. ie hide/ unhide or “expert “ view.
hitechRadio
They RID must be different from (assuming you have a sys key). Duplicates radio ID's (aka...Unit Id) on a trunking system will/may cause problems. You should contact your trunk system admin and let him know what your trying to accomplish, he will help you out!!!
