XTL5000 programming question
KA3HJC
Walkersville, Md
I recently purchased a fairly new XTL5000 with a remote O5 control head. Unit has the latest R20 firmware and a large number of options in the flashcode. It previously had numerous frequencies loaded in the codeplug ranging anywhere from 760-869 mhz. These were deleted by the seller and a single frequency pair of 851/806 were programmed in it. I read the codeplug using R20 software and saved same to my hard drive. I programmed several conventional repeater frequencies in the 851-853 mhz range but when I attempted to write to the radio, I received a notice saying essentially, you are about to write/clone a non rebanded codeplug to a rebanding capable radio. Never ran into this before. Will it have any detrimental effect on the radio? I apologize if this question has been asked before. I checked numerous forums and did not see anything similar before posting here. Thank you in advance Bill
KM4OKT
Virginia, EM86
Click Trunking in the tree with the codeplug open, Trunking Configuration, and under the General Tab click Rebanding Enabled. Should fix your problem.
clbsquared
Isle of Wight County
You need to select "Rebanding Enabled". By default on a new codeplug, it is not selected.
Edit: Sorry about giving the same answer. As I was typing, KM4OKT beat me to it.
Sent from my HTC One A9 using Tapatalk
