XTL5000 W series Disable Ignition Sense
KG5HHS
Euless, TX
Hello Everyone,
I have a XTL5000 Dash mount VHF (Model Number: M20KSS9PW1AN) with a W7 control head. This will be used as a base radio. I am trying to disable the ignition sense so that it will power on with out having to apply that power to the ignition sense wire. In Radio Wide>Advanced, I have ignition switch set to blank. I want to say there is another place in CPS for ignition sense, but I can not remember. Any advise/help would be appreciated.
wgbecks
NE Wisconsin
Read the existing codeplug from your XTL5000 then go into the Radio Wide section and open the Advanced tab.
Now look down the left side of the page for Ignition Switch. Set it to Blank and write the codeplug back into the radio.
Anderegg
Enter text in this field
San Diego
For a dashmount W series to be able to do ignition sense disable, you must short a couple of spots inside the control head circuit board. I believe that once you short this in the head, you might not be able to utilize the ignition sense as an option, as the radio will always sense power to the wire even if the accessory plug wire isn't connected to anything. I've got a few old Astro radios with the W series control head ign mod, just so I wouldn't have to wire a second lead for them to simply turn on.
Paul
