XTL5000 with 03 head getting error 14/10 & 15/10 then channel mismatch
wb6sub
Antelope Valley, CA
I am using 03 control head on a xtl5000 vhf radio. When powering up; error 14/10 then 15/10 flash then show channel mismatch. I swapped to known working 03 heads off my other radios and get the same result. I am able to read the radio and write a codeplug but still have this same problem. I switched to another radio and am able to program fine. I am a ham radio operator and am trying to program with ham 144-148 bands only. My software is ATRSO 25 CPS 20.1.0.0.
Please help. I just purchased this radio and want to install in my car soon.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
It’s not ‘channel’ mismatch, it is ‘Control Head‘ mismatch’
You need to tell the radio what control head you have on it.
wb6sub
Antelope Valley, CA
thank you so much! I am trying to find it where I select the 03 control head in the software and am having trouble locating it. Please help with this
kayn1n32008
Sector 001
I’m not sure. There are others that can answer that. Be patient, someone will have an answer for you.
GTR8000
NY/NJ Database Guy
BEE00
Tools > Change Control Head
sfd119
Do you have multiple control heads? There is a procedure to change the O5 heads for multiple operations, but I don't think there was a way for the O3s...at least referenced in the manual.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Those errors would seem to be bus errors. Make sure you don't have any DEKs, VRS or Siren/PAs enabled. Also check the number of control heads you have defined.
These are all under RadioWide.
