XTL5000
emndive
boston, massachusetts
does anyone know if you can tone out minitor pagers by using a xtl5000? and...... is there a way to change the squack noise when you tx? example make it longer and a different noise?
Motoflightmedic
ÆS Ø
U.S.A.
You can Two tone encode with an xtl5000. as far as the "squack" noise i am not sure what you are talking about. MDC1200 maybe?
eclipse175
New England
Quick call is the signaling you would use to open pagers. We have it setup in a couple of our xts2500s. The squak or mdc1200 is manipulated a few ways. The receiving radio can be programmed to mute part of the noise which makes it sound like a short blip. If you check the box "preamble during pretime" it will cause the noise to sound a little different. The noise is data packets sending the ID so there isn't really a way to make it sound different.
