XTL5K Programming Cable
K6GBW
Montebello, CA
Does anyone know of an aftermarket supplier for the HKN6163C programming cables? The only ones I'm finding are north of $200.00. I know there used to be an aftermarket one that someone in the Pacific Northwest made but I can't seem to find it.
Any leads are appreciated.
Brian
K6GBW
Montebello, CA
Thanks tweiss, but it looks like they don't have it. This is the cable that goes on the back of an XTL5000 when using the O5 HHCH microphone. It has the wires for ignition sense, speaker and USB for programming. So far all I can find is some new old stock from Mother Moto at over $200.00. I just have a problem with paying over $200 for a cable, but if I don't have a choice I guess that's what I'll have to do. Just wanted to give finding the alternative a good college try.
KevinC
OBT Matters
Super Moderator
Home
I guess saying I have 3 of them would just be mean. And no, I'm not selling any of them.
wa8pyr
Technischer Guru
Moderator
Ohio
Build one yourself from an accessory connector and a USB cable (keep the A end). You'll need the special pins from Motorola which aren't cheap, but one pack of them will go a long way. Built myself one this way for a total cost of about $30 plus half an hour working at the bench. Works like a charm.
vagrant
ker-muhj-uhn
California
I use a W3 HHCH (hand held control head for those that don't know the acronym) with my XTL5000 and my programming cable also plugs into the back of the radio. I use the HKN6160B which is labeled on my cable. I do not remember where I purchased it, nor for how much, but it looks like they are around $60 now. I use some serial to USB cable to connect to it and program it with a Windows 7 tablet.
My Moto cable looks like the one below. I had the USB to serial cable already. I presume this cable would work for you as well, but I am not a Motorola professional.
marcotor
I ♥ÆS Ø
Sunny SoCal
Build one! It's only 4 pins for the connector, and you know someone who has the pins (and I do if he doesn't) and proper crimp tool for them :)
K6GBW
Montebello, CA
Argh...sorry gentlemen, I ended up buying one from a radio shop in Texas. I considered getting the B model but I only have a W11 machine and I wasn't sure it would work right with an adapter. So...I guess I'll be drinking the cheap beer for awhile, but at least I'll finally be able to program this thing. I struggled trying to find a way to get a radio into my Subaru Crosstrek. I finally settled on the XTL under the drivers seat with the HHCH microphone. Getting the power through the dash was a challenge, but everything else has gone pretty easy. I should have it by Friday and I can work on the codeplug over the weekend.
Thanks again for the leads!
