XTS 1500 Buttons Not Working
EMTLJB
Northern NJ
Anybody have any ideas where to look for programming errors when it comes to the programmable buttons on the XTS 1500 radio (display, no keypad).
The top button toggles back and forth (on its own) the assignment of the bottom buttons as does the upper button. The middle and lower buttons give no response at all.
I have checked the software button configuration and all looks good. Tried reloading the codeplug with no change. Tried clearing the button configurations and I still am getting the error tones. I'm thinking it may be a hardware issue at this point.
Thanks for the help and insight.
jim202
New Orleans region
You are not providing much information as to what your trying to get the buttons to do. No info, no reply is all your going to get.
Some pointers before you go off the deep end here. Many button functions are related to how the channel or zone personalities are set. Like if you program a button to scan, but don't have a scan list programmed for that personality, you won't get any scan. Many of the other selections work the same way. The same thing for a talk around or simplex operation on a repeater pair. If the T/A block is not checked for the channel, you don't get the function.
EMTLJB
Northern NJ
Jim - Thanks for responding back. Wasn't sure what information would be most valuable to someone trying to troubleshoot without having the radio in front of them.
I had the top button programmed to Scan, Upper to Nuisance Delete, Middle to Zone Bank, Bottom to TalkAround/Site Displ for trunking. Same configuration for conventional and trunking set-ups. All buttons had worked as programmed for 5 months until the user swapped batteries one day (always used Motorola Batteries).
Now the top button is toggling both scan and zone, upper button gives a error 'boop' and changes zones, middle and bottom buttons do not change functions or give any audible feedback. Programming shows the original configuration, however.
Hope this helps, let me know if you need any more details.
Thank you.
RKG
Boston, MA
The other possibility is that you have a flex issue. The side buttons communicate to the radio via a flex. Sometimes wiping a flex a couple of times cures erratic behavior.
Batwings21
Banned
Incorrect, on an XTS1500, PR1500, MT1500, XTS2500 the side buttons and PTT button are micro-switches soldered to the board, more than likely they have popped off the board and need to be reattached its a fairly common failure on these as well as the ht750/1250 if they are used roughly.
EMTLJB
Northern NJ
I could see how this would cause no response from the buttons. Would that also explain the wacky behavior of the top and upper buttons, though?
I think the user is not telling you the truth. I doubt this happened by him simply swapping batteries. I'd be more likely to believe that the radio was dropped or otherwise subjected to some sort of trauma. Any signs of damage on the case?
I'd start by opening up the radio and taking a close look inside, specifically focusing on the solder joints. Looks for signs that it was opened by someone who didn't know how to open it, etc.
RKG
Boston, MA
Quite right. I must have been reading side buttons but thinking front buttons, which wouldn't apply to OP's radio anyhow. Low brain voltage.
