XTS 2500/1500 Emergency rx
Giddyuptd
Here and there
We just had a few older AN 1500s 1.5 and couple of 2500s kicked up to their final firmware in the R9 range from around 4.
Reading from what ive found around R7 firmware added emergency rx recieve indication decode or was that only applicable to BN models or a specific flash option back then?
Everything's programmed but no rx EM decode on them. Just the usual mdc muting over a alerting for EM rx.
Everything's setup proper. Just couldn't recall if AN was even capable of it and they never added that feature to the AN models.
As said they are AN models, 1.5 and model 2s. 4 meg.
Adding a side note we had 2 BN 2500s and a 1500 BN kicked up to final R20.xx from the R4ish range and those will decode it or alert to it.
I'm aware of the memory limitations and so on with the 4 megs. Just cant recall if the AN even was capable of EM rx and I thought I recalled off top of head more around firmware 12 or 14 is where it offered the emergency alarm indicator.
These are your basic p25 conventional operation nothing added or fancy like you see out there.
Thoughts?
Edit: picking at them more I noticed the individual caller alert level was 0, and the tps menu had it set to no indication. So going to see if that does it. If so I need a slap to head. Still would like to know what exact firmware version offered it for memory sake.
