XTS 2500/5000 Questions
I am a little confused about the things I have found out about these radios! Can the radio Tx/Rx on the 800MHz digital PLUS the radio analog bands, i.e. 462.700MHz? I see that they have different models but can one radio do it all? Also if you have the Model lll (the one with the keypad) can you program the radio in the field without the software or a computer?
Thanks,
Nathan Rischling
JnglMassiv
Chicago / 016
The radios are single band only.
The radio has to have the front panel programming feature enabled. You'll need to have the flashcode upgraded if its not already enabled.
Thanks!
That helped a lot, and saved me a lot of time!
Also, where do you find the details of the flashcode upgrade?
Once again, Thank you!
bezking
On the Road
Hi there, if you provide us with the flash code we can tell you what features are installed. If you want to upgrade your flashcode, contact your Motorola dealer.
